1999 Ford Escort
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
THOMASONKERRY
Check engine light has been coming on then going off for about a month. Had it checked and was told it was the EGR Valve. Was driving it and when I pulled into my driveway it died. Has never done this before. Left it overnight and when I teied to start in in the morning it would not start and made this horrible grinding and very loud noise like metal hitting metal.ied to start it a couple more times after that and the loud metal on metal sound stopped,but it still wouldnot start. Checked to make sure the fuel pump was working and it is getting gas. Then I changed all the spark plugs and wires. Seems like it wants to start,but it won't.
Sep 6, 2010 at 4:57 PM
  • 110,251 POSTS
Was the grinding noise coming from the starter? As far as the fuel, did you check pressure? Is the engine getting spark?
Sep 7, 2010 at 1:16 AM
