1999 Ford Escort
EUGENIA
Engine Mechanical problem
1999 Ford Escort 4 cyl Two Wheel Drive Automatic
my car bucks an misses when i take off from a red light it moves good, when i am moving ,but the rpm seem to go up high and then when i let off of the gas it bucks
Jul 26, 2010 at 9:08 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 26, 2010 at 12:46 PM
