1999 Ford Escort
100,100 MILES • 4 CYL • FWD • AUTOMATIC
SIWYTOM1957
  • 7 POSTS
While driving the engine shuts down by itslef. I then start the car and it starts fine. NOW IS NO START.
Jun 21, 2010 at 3:31 AM
  • 75,988 POSTS
Hi siwytom1957, Welcome to 2carpros and TY for the donation
Lets do below to determine if its a fuel or spark issue and get back with some testing results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 21, 2010 at 10:42 PM
