1999 Ford Escort
GKGMTURNER
Air Conditioning problem
1999 Ford Escort 4 cyl Front Wheel Drive Manual
ac not blowing cold air and is dripping on the floorboard
Jun 14, 2010 at 12:44 PM
BMRFIXIT
  • 19,053 POSTS
Check AC evaporate drain plug if clogged
check AC low side line if cold suspect blend door actuator
Jun 14, 2010 at 2:41 PM
GKGMTURNER
found out when the wife got home the fan was not blowing....must have hung up..which to me explains the over condensation from the evaporator coil...checked it out and got the fan motor spinning and working perfect
Jun 14, 2010 at 3:44 PM
