I am working on a 1999 Ford Escort, 2.0L with 78k miles. The engine began running very rough and surging at cruising speed. Check engine light gave a P0304 generic code and no other codes. I replaced plugs, wires and coil pack. No help. Voltage readout from the front O2 sensor varies from .000 to .950 volts, but I have nothing to suggest that it is the problem. I am reluctant to continue replacing parts with no clear indication of the problem. What should I check or replace next?
Jun 16, 2007 at 8:41 AM
