1999 Ford Escort
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
ELABOODEE
my car run rough and when I decelerate or stop it give gas smell and want to stop though it keep running but it shake and run rough
Aug 28, 2009 at 10:56 AM
  • 75,988 POSTS
Could be running on the rich side due to the following: A bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Aug 28, 2009 at 11:01 AM
