1999 Ford Escort
PAULSPUR
1999 Ford Escort
How do I replace car horn? I know it is under and behind right side headlight.
Aug 27, 2008 at 1:36 PM
BMRFIXIT
  • 19,053 POSTS
Finding the horn is the hardest
it is mounted on by ½ in bolt
remove the bolt and disconnect the wires
Aug 27, 2008 at 1:49 PM
BADBO
  • 35 POSTS
The horn is located on the right side. Look under the right side between the bumper and fender wall. It is really a 5/16 bolt which takes a 1/2 in wrench or a 13 mm wrench to remove it. Hope this helps.
Badbo
Aug 27, 2008 at 2:04 PM
