1999 Ford Escort
16,000 MILES • 4 CYL • 2WD • AUTOMATIC
GRITZ2YA
test said cyl. 2&3 were misfiring, tried injectors, catyl. conv., checked timing, coil pack, plugs..... fuel rail pressure (high and low)........... and plug wires, any suggestions?
Oct 21, 2010 at 1:53 AM
WRENCHTECH
  • 20,758 POSTS
What's the compression?
Have you verified good spark at the plug end of the wire?
Are the plugs staying snow white or getting dark?
Is it consuming any coolant?
Oct 21, 2010 at 2:00 AM
GRITZ2YA
compression is very good, just put new irridium plugs in it for 6.99 each the old plugs looked kind of white like it may be runnin lean. good spark at plug side of wire, checked injectors, fuel rail and pressure, & no coolent leaks.
Oct 24, 2010 at 9:46 PM
WRENCHTECH
  • 20,758 POSTS
What are the compression readings?
Use a noid light to check for injector pulse.
Perform an injector balance test.
Post back with the results after you do the testing.
Oct 24, 2010 at 10:17 PM
