1999 Ford Escort
SIWYTOM1957
  • 1999 FORD ESCORT
  • 4 CYL
  • FWD
  • 100,100 MILES
While driving the engine shuts down by itslef. I then start the car and it starts fine. NOW IS NO START.
Monday, June 21st, 2010 AT 10:31 AM
Hi siwytom1957, Welcome to 2carpros and TY for the donation
Lets do below to determine if its a fuel or spark issue and get back with some testing results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, June 22nd, 2010 AT 5:42 AM
