1999 Escort, Blower Not Working
JBREDESON
1999 Escort, 135,000 miles 2.0L engine.
1) Something that had happened to me. After an oil change, car ran very rough, stalled once in a while. Also at high speed, car seemed to lurch. Found it to be a cracked PCV valve case.
2)When the heater, AC or defrost turned on, the fan does not work. Checked all of the fuses visably, next step?
Jun 26, 2007 at 7:35 AM
STEVEN MARR
[quote:c41a776182="JBredeson"]1999 Escort, 135,000 miles 2.0L engine.
2)When the heater, AC or defrost turned on, the fan does not work. Checked all of the fuses visably, next step?[/quote:c41a776182]
JBredeson, saw your questions while I was researching a problem with my own Escort. Regarding your blower, check the plug on the blower housing under the dash on the passenger side of the car. I have had the plug disturbed by people hitting it with a foot causing the fan to not run. If it isn't that, check for power to the plug with a VOM. After that, if you have jumpers, try to power the fan motor directly to confirm if the motor is good or not.
Jul 19, 2007 at 1:43 PM
