Drove her home, then minutes later wouldn't start. Just a clicking sound
Wednesday, October 15th, 2008 AT 11:28 AM
2CARPRO JACK
MECHANIC
Try a jump start, if that doesnt work, it may need a starter. Test for 12 volts at the small wire on the starter, if it has it, the starter is bad
SPONSORED LINKS
Wednesday, October 15th, 2008 AT 12:12 PM
KAREN HIGHTOWER
MEMBER
Tried the jump start already, no go! Not a click or anything when trying to start. Had just driven the car and was leaving again & it wouldn't start this time.
Wednesday, October 15th, 2008 AT 12:56 PM
2CARPRO JACK
MECHANIC
OK, need to check for 12 volts at the small wire on the starter, if it has it, then the starter is probably bad. Are the headlights bright?
