Please could you tell me is it easy for a confident (little better than) novice to be able to (with full instructions) replace the rear wheel bearings?
Saturday, April 25th, 2009 AT 4:37 PM
BMRFIXIT
MECHANIC
Raise and support vehicle. Remove rear wheel assembly. On drum brake models, remove rear drum. On disc brake models, remove caliper and rotor. Remove and discard axle hub retaining nut. Remove hub from vehicle and replace
