1998 Ford Escort transmission??????????????
118,000 MILES • 4 CYL • FWD • MANUAL
JDUNNE2341
I have 98 escort... The Car runs fine until it warms up...... after it hits opoerating temp it wants to stalll (bucks and kicks) if you put the car in neutral it will run fine.... if you let it stall it wint start again until it cools.. also when this happens the battery is dead and yoou have to charge it.. coiuld this be a trans problem or crankshaft sensor????
Nov 23, 2008 at 3:02 AM
BMRFIXIT
  • 19,053 POSTS
So the car will stall and will not restart until u have charged the battery
DID U CHECK THE ALTERNATOR AND CHARGING SYSTEM ??
check fuel pressure
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 23, 2008 at 9:55 AM
