1998 Ford Escort timing belt replacement.
STEVEWITHAS
  • 1998 FORD ESCORT
Engine Mechanical problem
1998 Ford Escort 4 cyl Front Wheel Drive Manual 140xxx miles
My 98 ford escort has a 2.0 sohc engine and it broke its timing belt. I have since replaced the belt and it will still not run. I was told by 2 people that it was an interferance engine and that it was not an interferance engine. I'm 100% shure that my TDC marks on the crank and cam shafts where at TDC and I even rotated them and checked them again. And all was well, however It still will not run. The plugs, wires, and coil all apear to be in good shape.
Please Help
Steve
Monday, June 1st, 2009 AT 3:24 PM
BILLYMAC
  • 2,204 POSTS
Hi do you have compression?
Tuesday, June 2nd, 2009 AT 8:48 PM
STEVEWITHAS
What would it mean if I didnt have compression?
Thursday, June 4th, 2009 AT 9:15 AM
BILLYMAC
  • 2,204 POSTS
Hi, it means it is out of time. Or if it is not out of time, then you have bent valves
Thursday, June 4th, 2009 AT 5:09 PM
