HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Ignition
Timing
Ford Escort timing?
GTH5255
MEMBER
1998 FORD ESCORT
Engine Mechanical problem
1998 Ford Escort 6 cyl Front Wheel Drive Automatic
How do you set the timing on a 1998 ford escort 2.0 electronic ignition?
Monday, August 25th, 2008 AT 9:52 PM
BMRFIXIT
MECHANIC
I attached some diagrams for you.
Wednesday, August 27th, 2008 AT 9:34 PM
Please
login
or
register
to post a reply.
Related Ignition Timing Content
Timing
I Just Replaced My Timing Belt And Trying To Start, But It Will Not Turn Over. I Give It Gas And It Almost Starts. Both Points Line Up...
Asked by
Stevenmote
1998
FORD ESCORT
Every Morning I Try Starting My Ford Escort But Every...
Car Ticks Over Very Low
Asked by
Tim88
1998
FORD ESCORT
1998 Ford Escort Can't Change Gear
This Has Been Happening For Sometime Now. I Start The Car And Then I Can't Change Gear. I Thought Initially That Car Just Needed To Be...
Asked by
neha8000
1998
FORD ESCORT
1992 Ford Escort Timing
Engine Mechanical Problem 1992 Ford Escort 6 Cyl Front Wheel Drive Manual I Got The Timing Belt On (replaced) Without Getting The...
Asked by
bclarin2008
1992
FORD ESCORT
Timing
How To Adjust The Timing?
Asked by
ericconkin
1999
FORD ESCORT
VIEW MORE
Low Engine Power
Symptoms of Low Engine Power
Fix an Engine with Low Power!
