1998 Ford Escort Temp gage is on hot
SCOTT LANE
Engine Cooling problem
1998 Ford Escort 4 cyl Two Wheel Drive 140998 miles
The Temp gage is pegged on hot , over the red line.
However it does'nt matter if the engine has sat overnight and has completely cooled down. I unpluged the senor connected to the water pump, but that did'nt change anything. What could be the problem?
May 13, 2010 at 9:24 AM
  • 75,988 POSTS
Check and test the engine coolant temperature sensor at left rear of engine
May 13, 2010 at 9:55 AM
