1998 Ford Escort stop light switch
74,959 MILES • 4 CYL • 2WD • AUTOMATIC
BOSOXROCK757
have replaced the stop light switch 6 times in the last 7 months .. what is causing this switch to keep going bad ? ideas?
May 24, 2010 at 11:50 AM
  • 31,937 POSTS
check that you do not have an earth leak in the brake light circuit, but even this should not affect the switch, is switch burnt out or failing physically?
mark (mhpautos)
May 24, 2010 at 11:55 AM
