1998 Ford Escort running rough
82,997 MILES • 4 CYL • 2WD • MANUAL
STEROB_SC
my escort seems to be running on 3 cylinders most of the time and sometimes when i just tickle the accelerator with my foot it sometimes runs on 4 but only on high revs ive changed all the sensors apart from crank and camshaft ive changed the air flow meter and the coil pack its sparking on all 4 cylinders could you please help me as what to do thank you
Feb 6, 2008 at 6:53 AM
BMRFIXIT
  • 19,053 POSTS
[quote:86c60cb612="sterob_sc"]Engine problem
1998 Ford Escort 4 cyl Two Wheel Drive Manual 82997 miles
my escort seems to be running on 3 cylinders most of the time and sometimes when i just tickle the accelerator with my foot it sometimes runs on 4 but only on high revs ive changed all the sensors apart from crank and camshaft ive changed the air flow meter and the coil pack its sparking on all 4 cylinders could you please help me as what to do thank you[/quote:86c60cb612]
I would start by doing a cylinder balance test .
do you have a check engine light ?
if so scan for code
check injectors and clean if needed
let me know
Feb 6, 2008 at 10:41 AM
