1998 Ford Escort replace alternator
FORDSTAR
1998 Ford Escort 15000 miles
what is the best way to remove and replace the alternator?
Nov 4, 2009 at 5:35 PM
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable.
Disengage drive belt from pulley.
Remove power steering hose bracket from generator bracket.
Remove generator mounting bolts.
Remove generator.
Disconnect wiring from generator.
To install, reverse removal procedure.
Tighten lower generator bolt to 15-22 ft. lbs. (20-30 N.m).
Tighten upper generator bolt to 29-44 ft. lbs. (40-55 N.m)
Nov 4, 2009 at 9:55 PM
