1998 Ford Escort radiator fan is not working along with tem
ASEMENJUK
Engine Cooling problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic 141k miles
radiator fan is not working along with temperature gauge showing wrong temperature. thermostat & sensor or sender (don't know right name ) on upper part of thermostat was changed. same result - they are not working.
Nov 16, 2008 at 4:47 PM
  • 75,988 POSTS
All those good stuffs replaced and still happening-could be a wiring problem ,the fan relay or the computer itself
Jun 6, 2020 at 5:45 AM
ASEMENJUK
what is the name of the sensor located on lowest part of thermostat? and what is it for?
  • 75,988 POSTS
Item no.33 is the engine coolant temperature sensor I've looked for an engine temperature gauge sendng switch non was listed.
Jun 6, 2020 at 5:46 AM
ASEMENJUK
We change the gauge sensor, seems like temperature gauge is working now. What is the temperature, when radiator fan is turning on? Tha car is Escort ZX2 1998.
