1998 Ford Escort problem
TEXBUCK
I have a 1998 Ford escort with 120,000 miles. It idles rough and has no power. I changed the coil pack after realizing that #1 & #4 plug was not firing. I also noticed the car will keep running when I unplug injector #1 & #4 but will die when I unplug injector #2 or #3. Fuel pressure is good and it has new plugs and wires along with the new coil pack. Your help is much appreciated.
Mar 3, 2006 at 1:25 PM
TEXBUCK
I found the problem. There is a 3 wire quick connect that plugs into the coil pack that had a broken wire causing only one side of the coil to fire.
Mar 6, 2006 at 1:04 PM
