1998 Ford Escort powerless
12,000 MILES • 4 CYL • 2WD • AUTOMATIC
CJBARNES
I have replaced plugs wires and all vacuum hoses, it has a hard time starting and takes 10 minutes to get to 40 miles an hour. My father worked as an engineer for fords for 30 years...i am a woman and need some assistance now, lol I have had 3 different people say to replace the pump it is bad and the filter too at the same timebut don't want to replace them if they aren't bad.
Jan 12, 2009 at 1:02 AM
RICK 08
  • 54 POSTS
HI: have you scanned engin codes?
Todays cars are complex, Without this info the most you could expect may be at best a valueless guess.
As you indicated throwing parts at this is a waste of dollars and time. ? Scan info?
Jan 14, 2009 at 9:36 AM
KARENCAREN
  • 72 POSTS
better check your engine code. Or just call your father and have that look at. Don't replace anything first.
Jan 15, 2009 at 12:32 PM
