1998 Ford Escort P0750 Trouble Code & Shifting Issues
113,000 MILES • 4 CYL • 2WD • AUTOMATIC
CEREBRO
Please help, my service light came on 2 weeks ago. Got the code of P0750 shift solenoied A malfunction. Took Solonied's out had tested, they tested find, replaced with different ones still. Car worked good for 1 day the code came back. Car will drive fine on startup and then for about a mile then downshifts to 2nd and will not shift back up even after coming to stop at stoplight. Any ideas? Thanks
May 8, 2008 at 11:32 AM
BMRFIXIT
  • 19,053 POSTS
1. check circuit continuity . ( check PCM connector and ensure connector and terminals are in good condition )
2. check for short to power or ground (need to use a DVOM check volts and Ohm related wiring )
3. check tranny external harness
May 8, 2008 at 10:05 PM
