1998 Ford Escort Long crank
134,000 MILES • 4 CYL • 2WD • AUTOMATIC
DEVSTAR2003
I have a '98 Escort ZX2. Every time I try to start it up in the morning before work (after sitting overnight) it takes about 4-5 seconds to crank before my engine fires. I have replaced the spark plugs, air filter, and fuel sensor, but I'm not sure if it is my fuel pump or not, so I just want to make sure before I go out and spend more money on a part I may not need. Any help is appreciated. Thanks!
Jul 14, 2010 at 3:10 AM
  • 110,248 POSTS
Here are directions for checking fuel pump pressure. Check it and let me know what you find. Also, pay attention to pressure drop off when you turn the key off.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
joe
Jul 18, 2010 at 5:33 PM
DEVSTAR2003
I just replaced the fuel pump and filter, and it still cranks forever. What else could it possibly be???
Aug 1, 2010 at 11:22 AM
  • 110,248 POSTS
Was the pressure low before replacing it? Also, did you check the regulator?
Aug 1, 2010 at 4:58 PM
DEVSTAR2003
The fuel pressure was at 30 before I replaced it and no I have not checked the regulator and don't know how. I've poured over $1000 into fixing this stupid car and am not willing to shell out more for a car valued at only $1500 anyway. Thanks for your help, but I'm just going to trade it in a few months for a better car. I'm through messing with it, unless you can guarantee the labor on checking and/or fixing the regulator is less than $200, you can forget about it. I'll just run it like it is until I trade it in.
Aug 2, 2010 at 12:52 AM
  • 110,248 POSTS
The fuel pressure should be between 35psi and 55psi. A regulator is around 100.00 aftermarket. If you review the How To check the fuel system, you will see it is easy to do yourself. When engines crank for a long time, many times it is due to needing a tune up or low fuel pressure. The regulator can cause that. I can't guarantee anything without checking it, but that is where I would start. The old fuel pump may have been good.
That is the best I can offer without being there. If you have other questions or concerns, let me know.
Aug 2, 2010 at 4:56 PM
