1998 Ford Escort interferance engine question
91,000 MILES • 4 CYL • FWD • AUTOMATIC
GDGOOD11
  • 12 POSTS
my mechanic says my timing belt slipped causing many of my valves to get bent. wants $1500 to do the repair but car is not worth it.
Q: i thought this 2.0 dohc engine was a non interferance engine? if it is non interferance shouldn't it be able to avoid bending valves if this situation happens?
Sep 9, 2010 at 4:41 PM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_escort_zx2_timing_belt_1.jpg
Look's like your engine is interference fit so it is possible to damage valve's if the belt slip's.Sorry for the bad news.
Sep 9, 2010 at 5:36 PM
GDGOOD11
  • 12 POSTS
thanks....how were you able to find out? some of the websites i looked said it was and some said it was not. very confusing. i was thinking that maybe this guy was b.s.-ing me.
Sep 10, 2010 at 8:24 AM
SATURNTECH9
  • 30,869 POSTS
I found it on Mitchell ondemand it's the online repair manual that all the moderators use on this site.I posted a screen shot from it that says with the timing belt off not to rotate the crank shaft or cam shaft or you can damage the valve's.
Sep 10, 2010 at 9:18 AM
GDGOOD11
  • 12 POSTS
thanks for the information. that helps quite a bit. i guess i'm now the proud owner of a 1998 boat anchor. can't be worth the money it would take to get it fixed.
Sep 10, 2010 at 3:43 PM
SATURNTECH9
  • 30,869 POSTS
Your welcome at least now you know what's going on.
Sep 11, 2010 at 3:47 AM
GDGOOD11
  • 12 POSTS
ya it's too bad....the body and interior are in mint condition. i'm almost thinking about dropping a rebuilt motor or a used low milage engine in that thing and keeping it going. would be a lot cheaper than a new car or even a good used car. any tips on following through on an idea like that? thanks again for your help.
Sep 11, 2010 at 4:00 PM
SATURNTECH9
  • 30,869 POSTS
Yeah it would be cheaper then replacing the car if you go with a used engine get the lowest mileage you can under a 100,000 mile's.Make sure the used engine you get the timing belt,thermostat,and water pump changed.If you go with a rebuilt engine make sure you find a rebuild place that has been around a long time that is a quality place.
Sep 12, 2010 at 6:02 AM
WRENCHTECH
  • 20,760 POSTS
This is a different expert and I wanted to jump in here to let you know that some of this info is incorrect. Your engine IS NOT an interference engine. The 2.0 DOHC is a free wheeling engine in every body except the Probe. The Probe has the only interference engine. I have repaired many of these with broken belts and never had any valve damage.
https://images.2carpros.com/forum/automotive_pictures/561653_Ford_interference_engines_1.jpg
Sep 15, 2010 at 5:38 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1998_ford_escort_20_dohc_timing_belt_1.jpg
That is a screen shot from mitchell ondemand for replacing the timing belt for the 2.0L Dohc vin3 that is where i got the info for the engine being interference fit.But since wrenchtech said that he has worked on them and they are not interference fit then i would say that mitchell ondemand has made a error in saying that.I would put a new belt on the engine and see if it start's and what the compression is.Thank you wrenchtech for correcting that error.
Sep 15, 2010 at 6:04 AM
WRENCHTECH
  • 20,760 POSTS
My screen shot is from Alldata
Sep 15, 2010 at 6:09 AM
WRENCHTECH
  • 20,760 POSTS
Let me add one more thing here about this engine. Whomever is doing this job, if they do not have the special tools, do not even attempt it. I have had to redo a number of these done by other techs that had a PO340 that couldn't be resolved after changing the belt all because it was timed incorrectly. Nearly every one had already replaced the PCM for nothing before bringing it to me too.
Sep 15, 2010 at 6:20 AM
GDGOOD11
  • 12 POSTS
THANKS VERY MUCH GUYS FOR HELPING ME TO CLEAR THIS UP. I WAS ABOUT READY TO JUNK THIS CAR BUT I FEEL A LOT BETTER ABOUT FIXING AND KEEPING IT. MUCH APPRECIATION FOR ALL THE INPUT.
Sep 17, 2010 at 8:12 AM
SATURNTECH9
  • 30,869 POSTS
Your welcome that's what were here for to help people.
Sep 17, 2010 at 8:45 AM
