Hi there
The engine light came on about 25 miles ago
when I took the car to a garage for engine light check up i was told it was the catalytic converter was the problem I had explain to the mechanic that the catalytic converter was replace a year ago along with the o2 senser
Is there other reasons for the light to come on
I have disconnect the positive on the battery
wait about 20 sec reconnect the positive light goes out for 3 wks then comes back on
Ant suggestions for this problem
Thank you
William
Thank you
William
Apr 15, 2010 at 6:53 AM
