temperature guage and the engine cooling fan has never worked?
1998 FORD ESCORT
89,000 MILES • 4 CYL • 2WD • MANUAL
HEAPS
I have no movement at all on my temperature gauge and the engine cooling fan has never worked. Am i looking at two seperate faults here ? or is this more likely to be the temperature sensors. I say "sensors" as I have a repair manual and im confused as it states coolant temperature sensor and temperature sender. Are these the same or different locations also i have checked the fuse for the engine cooling fan and is ok. (30amp)
Apr 7, 2009 at 2:49 AM
SQM
  • 6,383 POSTS
On this vehicle the radiator cooling fan is controlled by Constant Control Relay Module (CCRM). A faulty CCRM will not allow the fan to come on.
The module is located under the hood on the right hand side (if you are facing the engine), I have attached diagrams for your reference.
The temperature sensor can be connected to the fan issue but check the CCRM first as it is a fairly common issue.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
I have attached the diagrams including the wiring schematics for your reference.
Sep 20, 2021 at 5:19 AM
