1998 Ford Escort engine
JESSE RAMIREZ
Engine Performance problem
1998 Ford Escort 4 cyl Automatic
car was running good then car stopped and now car wont start it cranks a little bit but to a certain point like if engine is stuck
Dec 4, 2009 at 3:53 PM
  • 31,937 POSTS
Hi there,
This may be a number of things, first pull the plugs and see how it cranks over, if it is ok, the starter may be faulty and cant work against the compression, if the engine is still not cranking over check the starter and the battery, start here.
mark (mhpautos)
Dec 4, 2009 at 7:35 PM
