I can not get my cvc shaft back into the trany ive pushed pounded ive tried everything any ideas
Saturday, January 12th, 2008 AT 9:45 PM
BMRFIXIT
MECHANIC
1ST make sure you have the correct axel
check the ring at the end of the shaft some times little grease will hold it better
SPONSORED LINKS
Saturday, January 12th, 2008 AT 9:55 PM
SPARKYZX2
MEMBER
Used grease and its the same shaft I took off so I know its the right one
Saturday, January 12th, 2008 AT 9:57 PM
BMRFIXIT
MECHANIC
All I think of is the ring at the end take it of and try with out it
if it works then its the ring see if you can get new one or fix it
dont drive car without that ring or axel will come out while driving
Saturday, January 12th, 2008 AT 10:55 PM
CRAIGFL
MEMBER
These rings can be very hard to put back in. I try to use heavy grease to keep it centered with the shaft as closely as possible because the taper inside is suppose to squeeze the ring down as you push so it goes into the groove. A hammering action is not what it needs-- a steady high force is required to compress the ring so it snaps into the groove.
