1998 Ford Escort codes p1744 and p0761
14,000 MILES • 4 CYL • FWD • AUTOMATIC
SAULVITE
my automatic transmission has these codes p1744(tcc solenoid) and p0761(shift solenoid stuck off) I can only drive it manualy, first, second then drive. otherwise it wont run. just change oil and filter, and nothing, add a little bit of lucas antislip and nothing. then i checked the computer for codes.
how are these two codes related?
can you provide a procedure to change solenoid "C"?
once removed how do i test it? and what else should i test besides selenoid?
pls provide do's and dont's, i don't want to have any mistakes, this is going to be my first trans. opened.
thank you!
Jul 15, 2010 at 1:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
DTC P1744 : Transmission Slip Detected = No TCC Operation or Transmission Slips
DTC P0761 : SS3 Solenoid Failure = Improper Gear Selection
Does reverse gear work fine? Other than having to manually change forward gears, does the transmission seem to do fine with no slipping or noises?
Jul 15, 2010 at 2:22 PM
SAULVITE
In effect the reverse works fine, and there is no noises, once I get from 1st to 2nd and then to drive gear the car runs smooth until I get to the stop sign and start manually again.
slips a little between gears, I assume it is because i'm not supposed to drive it manually.
any help is welcome. thank you guys!
Jul 17, 2010 at 2:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
OK, so the solenoid is the most likely culprit here then. to reach the solenoid you first have to remove and disassemble the valve body of the tranny. follow the steps below which will help in removing the valve body and the solenoids. also i have provided a link to a great video on how to test shift solenoids.. http://www.youtube.com/watch?v=24gkmDDV0C8
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2474.jpg
Jul 18, 2010 at 4:22 AM
SAULVITE
One last question do i repalce only shift selenoid c and will that probably eliminate p1744 also?
Jul 20, 2010 at 5:21 AM
SAULVITE
just lowerd valve body, all selenoids click ok, and feeding voltage is present, what else shoud i try?
Jul 21, 2010 at 6:42 AM
COOJOFRESH
saulvite did you ever resolve the issue? if so, how? dod you end up DIY or did you take it to a mech?
May 4, 2011 at 9:25 PM
ADAMPRINCE2
I know this post is old. However, for other people with the same problem I made a video on how to diagnose transmission codes P1744 P0749 P1740 P1742. I hope this helps someone solve their problem with low cost tools. http://www.youtube.com/watch?v=5-2T4qyL7JU
Oct 24, 2015 at 8:36 AM
