1998 Ford Escort Clutch
1998 FORD ESCORT
IANTHEGARDENER
Engine Mechanical problem
1998 Ford Escort Two Wheel Drive Manual 88955 miles
Driving towards my home address, went to change gear, really load noise & clutch pedal hit the floor & stayed there - unable to change gear at all. Is this just a clutch cable snapping or could it be the clutch itself? Don't have at home service with RAC. Does this car have a cable or is it hydraulic? Thanks
Feb 6, 2010 at 2:04 AM
BMRFIXIT
  • 19,053 POSTS
Clutch is a hydraulic, single, dry-disc design with a Belleville spring-type pressure plate.
The clutch master cylinder uses brake fluid and shares a common reservoir with brake master cylinder.
Feb 6, 2010 at 12:37 PM
