My car's brake lights are constantly on, which ends up blowing the fuse, and causes my car not to start. How do I fix this problem?
Feb 24, 2009 at 2:12 AM
DAVE H
✓Experienced Mechanic
check the Brake Pedal Position (BPP) Switch.......On top of brake pedal support.
BPP switch is wired to brakelight circuit. It signals the PCM when the brake is applied. The BPP input is used to adjust engine idle when A/C is in use and to control torque converter clutch lock/unlock strategy.
