1998 Ford Escort Brake Sensor Stuck?
1998 FORD ESCORT
140,000 MILES • 4 CYL • FWD • AUTOMATIC
VANESSA_ARASIN
My car's brake lights are constantly on, which ends up blowing the fuse, and causes my car not to start. How do I fix this problem?
Feb 24, 2009 at 2:12 AM
DAVE H
  • 13,384 POSTS
check the Brake Pedal Position (BPP) Switch.......On top of brake pedal support.
BPP switch is wired to brakelight circuit. It signals the PCM when the brake is applied. The BPP input is used to adjust engine idle when A/C is in use and to control torque converter clutch lock/unlock strategy.
Feb 24, 2009 at 2:20 AM
