1998 Ford Escort Bolt
130,000 MILES • 4 CYL • FWD • MANUAL
KADAY
Hi, i have changed the rear bearing near side on my escort 1.8 gti, when doing up the bolt it would not go the distance of the spindle thread, i over tightened it and round it off. I have brought another spindle and another new set of bearings and i have the same problem it goes so fare and then stops but i am being told there is only one bolt for this spindal what could be the cause.
Cheers Kez
Jan 24, 2009 at 10:50 PM
  • 110,251 POSTS
Hi:
Are you sure the bearing is properly seated? Is it possible to take a picture for me to see what is happening? Are you sure you have the correct bearings?
Feb 1, 2009 at 11:52 AM
