1998 Ford Escort bearings
RIKSHAW33
  • 1998 FORD ESCORT
Noises problem
1998 Ford Escort 4 cyl Front Wheel Drive Manual 140k miles
why have I had to refit back wheel bearing 5 times in 7 months, always back left. Axle seems ok
Thursday, July 30th, 2009 AT 9:00 AM
LAZYGAZER
  • 68 POSTS
From your subject you have noise in the rear left axle that you keep refitting.
Have you replaced the race as well as the bearing? It could be scoured from the original bearing. Also check your stabalizer bars and linkage they could be bent misaligning the axle assy putting force on the bearing.
Thursday, July 30th, 2009 AT 8:10 PM
