1998 Ford Escort AIR VENTS
KENBB
Air Conditioning problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic 138K miles
THE AIR ONLY COMES OUT OF THE DEFROST VENTS NO MATTER WHAT SELECTION IS MADE.
May 4, 2008 at 9:47 AM
BMRFIXIT
  • 19,053 POSTS
its a vacuum leak
check for a vacuum leak
check under the hood for a vacuum line that goes throw the fire wall to inside the car
it should have vacuum
and if so check if you have vacuum at the switch
May 5, 2008 at 1:48 PM
