1998 Ford Escort 1998 Escort ZX2 will not idle and bogs
FASTTALON97
  • 1998 FORD ESCORT
  • 4 CYL
  • FWD
  • 130,000 MILES
I have a 98 Escort ZX2 that will only start if you have the pedal to the floor. Once it starts, you cannot let off the accelerator otherwise it will stall. It also seems to be down on power as it does not rev very fast. It is very "boggy" sounding when revving it. When the motor is cranking over, it makes a sputter noise until it starts. Does this sound timing related, or worse?
Monday, September 20th, 2010 AT 7:12 PM
Do you have a check engine light and when was the last tune-up?
Clean out the idle air control valve, PCV and EGR valves to include the MAF sensor with an electronic cleaner CRC and test the throttle position sensor
Monday, September 20th, 2010 AT 7:21 PM
FASTTALON97
Thanks for the quick reply. The Service Engine Soon light is on but I have not had a chance to get any codes.
The spark plugs have been replaced as well as the IAC valve. Haven't done anything with the PCV or EGR valves.
Monday, September 20th, 2010 AT 7:26 PM
You need to get it scanned for code/s there's a problem within the engine management system, this is your starting point
Monday, September 20th, 2010 AT 7:27 PM
