1998 Ford Escort 1380-1381 codes appair check engine light
DALEOLY1
  • 1998 FORD ESCORT
  • 4 CYL
  • FWD
  • 140,000 MILES
Check engine light appairs. Put scann tool on it code 1380 and 1381 comes up can you help me on this.
Tuesday, April 13th, 2010 AT 4:24 PM
BMRFIXIT
  • 19,053 POSTS
Camshaft timing improperly set.
No oil flow to piston chamber.(Very common check this 1st )
Low oil pressure.
VCT solenoid stuck closed.
Camshaft advance mechanism binding (VCT unit).
Tuesday, April 13th, 2010 AT 8:27 PM
DALEOLY1
How do I know if the timing is set properly the car seems to run fine.
Friday, April 23rd, 2010 AT 5:46 PM
