1998 Ford Escort
160,000 MILES • 4 CYL • FWD • AUTOMATIC
JAKEGUNN
1998 Ford Escort ZX2, 160,000 miles.
When i first get in the car in the mornings i have to keep trying to crank the car its like its turning over but will not crank. On most days it will eventually crank but some days it will run the battery dead trying.
Once the car does crank it will sputter and try to die the hole time i back out of my driveway, when it does die it cranks right back up with ease. While moving and the rpms are up it runs perfect, but once i stop at a light or sign it will again try to die.
I have replaced plugs and plug wires, my family keeps telling me different things it could be including; IAC valve, oxygen sensor, fuel pump, etc.
If someone could tell my with confidence what it is i would seriously appreciate it and would become a regular member of this site, often times donating along with my questions.
Mar 15, 2010 at 5:36 AM
DAVE H
  • 13,383 POSTS
have the vehicle plugged into a diagnsotic computer/scanner to check for fault codes stored !
HARD START/LONG CRANK
Preliminary Checks
Check for vacuum leaks. Check fuel quality (octane, winter/summer grade fuel, methanol, etc.). Check air intake system and air cleaner for leaks and/or restrictions. Check battery condition and starter current draw.
ROUGH IDLE, STALLS, MISSES, HESITATION OR SURGE
NOTE:The Powertrain Control Module (PCM) is equipped with an over RPM/speed limiting function that will shut off fuel delivery when predetermined speed is exceeded.
WARNING:On some vehicles, vehicle may stall if engine is left running during refueling. Advise customer to always turn engine off during refueling to avoid contamination or damage to EVAP system.
Preliminary Checks
Check for vacuum leaks. Check air intake duct and air filter. Check ignition wiring. Check fuel quality (octane, winter/summer grade fuel, methanol, etc.). Check wiring harness connector for poor connections.
Dec 14, 2018 at 1:35 AM
