1998 Ford Escort
MIKEY360
Engine Mechanical problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic 77xxx miles
Im working on a friends car and it will start every time and run smoothly anywhere from 20 seconds to a few minutes then begins idleing roughly and gas pedal is unresponsive. It doesnt stall unless you put it in gear or touch the gas pedal and let off without pumping. had obd2 scan run and only code is EVAP canister purge valve which I believe it p1443. But from what I've read(this code seems common among fords) this wouldnt cause the above porblem. possible clogged fuel filter/bad fuel pump/IAC? trying to save them some money so I'm trying to avoid the guess and check method.
Jan 11, 2010 at 4:45 PM
MATHIASO
  • 1,209 POSTS
HELLO mikey360 Welcome to 2carpros Description of the code p1443 A fuel tank pressure change greater than a minus 7 inches of H2O in 30 seconds has occurred with purge (fuel vapor) flow less than 0.02 pound per minutes. Look for blocked fuel vapor hose between EVAP and fuel tank pressure senor. Blocked fuel vapor hose between EVAP canister purge valve and engine intake manifold Blocked vacuum hose between EVAP canister purge valve solenoid and engine manifold Or the EVAP canister purge stuck closed
https://images.2carpros.com/forum/automotive_pictures/46384_0900c1528008dcfe_1.jpg
Jan 12, 2010 at 2:11 AM
