1998 Ford Escort
140 MILES • 4 CYL • 2WD • AUTOMATIC
PRECONNECT
1998 Ford Escort ZX2, 140,000 miiles. Daughter in law driving to work and it just quit. Towed it home. Fuel pump is working, getting spark at all plugs. Tried starter fuid. Nothing. Checked timing belt, still intact. Turns over but absolutely not even coming close to firing. Any ideas?
Sep 20, 2009 at 8:55 AM
DAVE H
  • 13,383 POSTS
Hello ... thanks for the donation .. much appreciated You need to have a compression test carried out ... if you have spark and fuel at spark plug's the only thing missing is compression ... burnt/bent valves or faulty piston rings ??
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_59.png
Sep 20, 2009 at 12:32 PM
