1998 Ford Escort
BRYAN1978
Air Conditioning problem
1998 Ford Escort 4 cyl Front Wheel Drive Manual
my air conditioning pump turns on and the lines all get very cold when i turn on my ac. the only problem is that hot air blows continuously even with the ac turned on max. you can see and hear the ac cycling when turned on. weve checked, and there is plenty r134a coolant in the system. system tested in the normal range it was supposed to be. when I turn on the heat, it definitely gets hooter than with the ac on... please help asap...
Aug 8, 2009 at 6:14 PM
STEVEW84
  • 673 POSTS
I would check blend door operation.
Aug 10, 2009 at 4:52 AM
