1998 Ford Escort
133,000 MILES • 4 CYL • FWD • AUTOMATIC
JEELROD9205
My car has been running pretty rough and then the check engine light came on. I got the code read and it said that cylinder 3 was miss firing. I replaced the spark plugs and wires and also the ignition coil. But i still am having the same problem. Please help
May 24, 2009 at 10:26 AM
  • 75,988 POSTS
Replaced the sparkplug now check compression and injector for no.3
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
May 24, 2009 at 10:35 AM
