1998 Ford Escort
SUMMERNESS
Shakes or Wobbles problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic
Ok, so i just replaced my spark plugs and throttle position sensor and now when my car is in drive i can take off but it does not kick into gear until the spped is 25 mph and after that its smooth and when at a stop for a minute the shift begins to shake and make a noise like metal hitting and nobody can figure out what the problem is. My guess it could be transmission problems what do you think?
May 6, 2009 at 6:16 AM
BMRFIXIT
  • 19,053 POSTS
Had no problem prior to the work that was done
check firing order and check timing and timing belt
check ignition wires and coil
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 6, 2009 at 10:39 PM
