1998 Ford Escort
97,000 MILES • 4 CYL • FWD • AUTOMATIC
EMOMASHEV
When I am changing the timing belt should I change also the water pump and the gasket?
Feb 20, 2009 at 12:21 AM
BLACKOP555
  • 10,386 POSTS
change the water pump gasket, also inspect teh pump for leaking or if the impellers on the pump is wearing out, if it shows any of the signs you should replace it. at 100,000 if it hasnt been replaced yet, or if you didnt do regular coolant flushes and refills expect that the pump is getting old and should require replacement since you are already that far.
Feb 22, 2009 at 2:03 AM
