1998 Ford Escort
11,500 MILES • 4 CYL • FWD • AUTOMATIC
GATORTROUT
My wife has a 1998 ford escort with a 2.0 basic 4 cylinder car. The car seems to want to run fine until you put it in gear. I have cleaned the injectors and replaced the oringsl Replaced the idle air control valve, installed new motorcraft plugs and wires. There is no light on to pick up a code. Could it be the fuel pump or fuel pressure regulator? Please help, as this is very annoying. I have a friend who is a ase mechanic at a local dodge dealership and I think that he is about as much as frustrated as I am. Thanks
Sep 15, 2008 at 5:14 PM
BMRFIXIT
  • 19,053 POSTS
will it stay running if you have your foot on the gas
if so check and adjust base idle
check egr operation and brake booster
Sep 16, 2008 at 2:56 AM
