1998 Ford Escort
65,600 MILES • 4 CYL • 2WD • MANUAL
ABDUL GHAFOOR
I CHANGED VACCUAM BOOSTER AND BREAK MASTER CYLLINDER, THAT TIME I CUT THREE SINGLE WIRES INFRONT OF BOOSTER. REPLACE THE BOOSTER AND RECONNECT THAT WIRES.BUT NO START THE ENGINE .CHECK ALL WIRING,FUSES,CUTOUTS,PLUGS ANDCOMPUTER. AFTER REMOVE THE PLUG WIRE FROM ENGINE AND IGINITION THE SWITCH,BUT NO CURRENT FLOW FROM PLUG.
Jul 2, 2008 at 8:06 PM
BMRFIXIT
  • 19,053 POSTS
Engine crank but no start
or wont crank
if no crank check the switch on top the clutch peddle
let me know
Jul 2, 2008 at 11:06 PM
