1998 Ford Escort
SOPHIASMOMMY050609
Transmission problem
1998 Ford Escort 4 cyl
My car starts fine. It will run as long as I'm driving but as soon as I stop my steering wheel freezes or something and then my car dies. I have coolant and oil I replaced the pcv valve, or watever its called. not sure wats wrong. help??
Jul 15, 2010 at 10:31 AM
  • 110,251 POSTS
You will loose power assist to the steering if the RPM's get low enough. Has the check engine light come on? Have you checked for vacuum leaks? Fuel pump pressure?
Jul 18, 2010 at 5:30 PM
