1997 Ford Escort thermostat
97,000 MILES • 4 CYL • FWD • AUTOMATIC
STU1997
i am currently having problems with my engine temp gauge and hot air blower and have been told the most likely cause is the thermostat but where is it located on the engine?
Jul 26, 2008 at 10:07 PM
MERLIN2021
  • 17,250 POSTS
Have a look where the engine and tranny bolt together, it should be right above that area, you should see the radiator hose attached there.
Jul 26, 2008 at 11:50 PM
STU1997
cheers for that but its not the thermo stat it works when i put it in hot water
Jul 27, 2008 at 1:28 AM
MERLIN2021
  • 17,250 POSTS
Your symtoms are that of an air buble, or low coolant and or blocked heater core, install a flush tee and flash the heater core.
Jul 27, 2008 at 8:02 AM
