1997 Ford Escort Starting
BSOULSMATT
Electrical problem
1997 Ford Escort 4 cyl Two Wheel Drive Automatic 121k miles
My car is sometimes starting and sometimes not. It makes a click and wont turn over or anything. It WILL jump start but my car battery is said to be good.
thanks!
Jun 10, 2010 at 12:11 PM
  • 75,988 POSTS
No cranking at times check and test below
The starter, starter relay, clutch switch/park and neutral switch/transmission range switch and ignition switch assuming the battery and connections are good.
Jun 10, 2010 at 12:14 PM
